Author Topic: Engine removal questions  (Read 5100 times)
Offline emery1990
Re: Engine removal questions
« Reply #20 on: 22 November 2011, 17:18 »
I've got that bolt out, but now I've snapped one of the rear mounts bolts, is that a problem or if I get the others out ok will it like lift out as there is no nut on the bolt?  :rolleyes:
Offline danny_p
« Reply #21 on: 22 November 2011, 22:27 »
it may do depends how well corroded in there it is,  if it won't just undo the 4 bolts holding the rear mount arm to the engine block,
then undo the 2 bolts that hold the mount to the subframe then deal with it on the bench at a later date
all the VW's have gone bar 1.
Offline emery1990
« Reply #22 on: 23 November 2011, 21:04 »
Thats what I've snapped one of the four holding the mount to the engine, the 13mm ones on top as you look at it, I'm taking friday off work so Ive got an actual whole day to play around!
Offline emery1990
« Reply #23 on: 25 November 2011, 11:09 »
Could do with a quick answer, want the engine out today! It's very wobbly, I think all those 3 bolts on the rear mount snapped  :undecided: I undo the big 17mm centre bolt that goes through the mount, but I cannot get the engine out. It is seperated from the gearbox, does the driveshaft have to come right out of the gearbox. I've split the flange, but this looks like the reason why the engine isn't coming out.
Offline Seanl
« Reply #24 on: 25 November 2011, 11:55 »
Better off disconnecting drive shafts at gb end, and leaving the box attached to the lump when pulling it out. Creates more hassle than it's worth taking the box off first
Offline emery1990
« Reply #25 on: 25 November 2011, 12:50 »
I am the bigger that that donut in the simpsons. I'm only taking the block out, so didnt even need to remove the driveshaft!!! Notice when the engine was out looking at the driveshaft thinking it's fing connected to the gearbox! £50 wasted on tools and now need new bolts and gasket for it  :grin:
To make it worse it fell apart and getting it back together with all that slime didnt help  :laugh:
It was a steep learning curve!
Where would I get the driveshaft bolts from ? Today.
« Last Edit: 25 November 2011, 12:54 by emery1990 »
