Author Topic: can i pick ya brain m8??  (Read 1632 times)
Offline trickeymickey65
« on: 11 November 2011, 19:47 »
help got a problem with mk3 gti four door, no power windows working in rear, no rear demist, wiper has anybody had the same problem, i am assuming this is a relay problem, but dont know which one or number would apprieciate assistance heads in the bin with it
Offline dazzawest1987
Re: can i pick ya brain m8??
« Reply #1 on: 11 November 2011, 19:59 »
wouldnt have thought there would be one relay for it all, i would start by checking all your related fuses, to these circuits, head over to the mk3 section for more help and info,
« Reply #2 on: 11 November 2011, 20:04 »
cheers dazzawest for fast and helpfull response cheerz   trickeymickey
« Reply #3 on: 12 November 2011, 16:04 »
still no joy fuses are all fine also no main beam works when it pleases checked bulbs and they are fine next thing i intend to do is check indicator stalk just seems strange so many things not working when they all worked fine before and done nothing major to rock the boat  confused i am please advise if poss cheerz   trickeymickey :wink: :sick:
Offline *tell*
« Reply #4 on: 12 November 2011, 19:23 »
i fitted a different boot lid and forgot to bolt the earth cables on  :lipsrsealed:
after i found this all was good. its two brown wires on the left side panel behind the
carpet could be worth checking.
« Reply #5 on: 13 November 2011, 12:49 »
will try thanks for response tried everthing else cant do any harm cheerz trickeymickey
