Author Topic: VW Polo brake pedal return  (Read 1164 times)
Offline chezz
« on: 11 November 2011, 18:09 »
My brake pedal is failing to return and as a result it is failing to shut the brake light off and this can only be shut off by physically lifting the brake lever back (the final inch of travel) with my toe/foot I highly suspect that the servo is the cause of the problem here, but I would be gratefull to know if anyone else has encountered this problem
I would like to add that there is a feeling that the linkage to the servo is catching - travel is far from smooth!
Offline weazgti
Re: VW Polo brake pedal return
« Reply #1 on: 12 November 2011, 20:55 »
Saw this in a garage years ago on a reno 5.
After everything being replaced a spring was put on the peddle in 5 mins.
Offline Seanl
« Reply #2 on: 12 November 2011, 21:29 »
I swear I've seen half a dozen french cars in the last month driving with brake lights on constantly. French sh!te!  :rolleyes:
Sorry I've not got a clue about the problem, just remembered when you said and decided to have a whing.  :lipsrsealed:
Offline chezz
« Reply #3 on: 12 November 2011, 21:55 »
I wonder if ETKA would show if there was a spring there originally, as I do not currently see one in situ.
