Author Topic: crap wheel bolt help?  (Read 3742 times)
Offline Cory
« on: 11 November 2011, 14:51 »
any idea how to get spinning wheel bolts out of rears?
Offline herr schimdt
Re: crap wheel bolt help?
« Reply #1 on: 11 November 2011, 15:04 »
do you meen a spinning locking wheel bolt
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #2 on: 11 November 2011, 15:16 »
Like This!!!!
http://honda-tech.com/showthread.php?t=2684546
 :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh:
PILLOCK!!!
« Last Edit: 11 November 2011, 15:18 by X4MGS »
For More Info Click To See;
Offline Cory
« Reply #3 on: 11 November 2011, 15:20 »
no, its a normal wheel bolt, i tightened it, but not super tight, as i was planning on adjusting my coilies after they were all fitted. went to undo the bolts, and now two are just spinning.
not massively kean on chopping up my wheels!  :shocked:
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #4 on: 11 November 2011, 15:33 »
Like This!!!!
PILLOCK!!!
That Tread Is Just Epic.... Worth a read when you have 10 minutes!!!
« Reply #5 on: 11 November 2011, 16:22 »
i theory if a normal bolt is spinning it meend the threads have gone in the hub or on the nut you may be able to undo the 2 goodd bolts then put outward pressure on the wheel and try undoing the other 2 nuts while excerting leverage on the wheel or drill them out or do the same as the thread that x4mgs posted which i think is brill if you do it that way post pics please
Offline clipperjay
« Reply #6 on: 11 November 2011, 16:24 »
Yeah please post pictures when you are doing this 200K meh+
Go to the tyre shop like the other thread mentioned, it could get interesting here! :smug:
Offline Cory
« Reply #7 on: 11 November 2011, 19:58 »
if i took off the hub nut, and wheel bearing, would the wheel not just come off of the stub axel attched to the brake drum?  does that make sense? because surely the wheel bolts aren't long enough to go through the brake drum and into brake back plate?
« Last Edit: 11 November 2011, 20:01 by Cory »
« Reply #8 on: 11 November 2011, 20:13 »
does it have rear discs if not you will be able to take the hub off as you say might take a bit of force though make sure the care is supported well on axle stands and if the bearing is tight make a makeshift slide hammer with some rope tied round the wheel and the other end tied to a 4 by 2 and give it a good yank obviously you do this at your own risk and i have nothing to do with any injuries caused to yourself
« Reply #9 on: 11 November 2011, 20:15 »
i had this problem.
undo all bolts you can.
get a mate to pull on the wheel away from the car.
try undoing  :wink:
i already said that
