Author Topic: Q? - Fitting a switch to unlock and lock car  (Read 1258 times)
Offline meanaman
« on: 11 November 2011, 13:45 »
Hi all, first post..so please be gentle.. :smiley:
I want to fit a switch in the boot that would activate my central locking (lock and unlock)..
anyone done anything similar ?
« Last Edit: 11 November 2011, 13:51 by meanaman »
Offline trog_nfs
Re: Q? - Fitting a switch to unlock and lock car
« Reply #1 on: 11 November 2011, 13:55 »
easy. Just locate the green and grey wires that go to the drivers door lock, pass 12v through either and the car will lock/unlock.
Use a momentary DPST rocker to make it work.
Offline meanaman
« Reply #2 on: 11 November 2011, 13:59 »
thanks for the rapid response.!
Offline trog_nfs
« Reply #3 on: 11 November 2011, 14:11 »
Any particular reason? You delocking or something?
Offline meanaman
« Reply #4 on: 11 November 2011, 16:56 »
yeah eventually...
but last winter i totally broke both front locks and snapped a key due to the cold...and thought/hoped that having a 'spare' switch in the boot would help get through the freeze!
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #5 on: 28 November 2011, 10:46 »
I'm glad I found this thread as ive got a genuine VW central locking dash switch that I've had for yonks and wasn't sure on how to go about installing it.
Offline trog_nfs
« Reply #6 on: 28 November 2011, 11:21 »
The problem is that the 12v switch only works when the engine is off; you can't lock the car with the switch whilst the engine is running.
The way around this I've seen is people using an actuator it pull/push the metal rod that goes to the drivers door pin.
