Author Topic: derv injectors  (Read 2803 times)
Offline EsSeX dAn
derv injectors
« on: 10 November 2011, 15:56 »
with diesel injectors on a non pd engine,if an injector plays up so it making the engine clatter,is it the whole unit to be replaced or just the nozzle? reason i ask is i was doing some research and says something about excessive noise stopping when you crack the union nut off for the injector basically its faulty
i think i love you.....
Offline Agreeable Slick
  • Unit
Re: derv injectors
« Reply #1 on: 11 November 2011, 08:30 »
Depends on the nozzle design.
It could just be the nozzle/shimming is worn and needs replacing in which case you would need to crack them open, re-shim/spring and then retorque them, and do a pop test on testing machine.
Or
They could just need cleaning (ultrasonically) to get the crap off them.
Offline EsSeX dAn
Re: derv injectors
« Reply #2 on: 11 November 2011, 08:37 »
any reccemondations on who can tesn an cleam them?
  • Unit
Re: derv injectors
« Reply #3 on: 11 November 2011, 08:39 »
I think in this instance it will be a case of getting on google and having a ring around.
There is always the option to build/buy your own pop tester & ultrasonic bath (although that's the expensive route :grin: )
Offline NoCrap
Re: derv injectors
« Reply #4 on: 12 November 2011, 09:55 »
By your user name i'm guessing you're in essex?
There's a good company near me in ipswich called Diesco, they specilise in diesel injection and are very helpful
Give them a call - http://www.diescogroup.co.uk/diesel-fuel-injection
Offline EsSeX dAn
Re: derv injectors
« Reply #5 on: 12 November 2011, 12:40 »
yes im from essex. ill give them a shout. thanks for that
