Author Topic: HOW TO: Hockey puck front engine mount.  (Read 18269 times)
Offline tshirt2k
  • Been there...Done that...
« on: 10 November 2011, 14:15 »
Did this a while back. May be of use to anyone experiencing alot of engine movement.
After reading about this mod I decided to give it a go myself as i couldnt find a how to.. I didn't want to go for a solid front mount because i didn't want alot of vibration. Also Vibratechnic are a bit expensive. I have already replaced the front mount previously but still had some movement.
I bought 4 Ice Hockey pucks from my nearest Ice skating rink (buy 5 if you want a stiffer mount).  The pucks are a solid rubber but are still pliable.
I Jacked up the car and supported the engine with a trolley jack. I then removed the front engine mount by removing the two bolts above and below Top bolt has a 16mm nut and the bottom is an 7mm (I Think) allen key .
(Those that have a plastic undertray will need to remove before you can access bottom bolt.)
The engine was jacked up to allow the mount to be removed.
Original swiss cheese mount. Left is upper section. Right is Lower section
To allow the pucks to fit the mount body, they needed holes drilled through the centres. I did this using a 20mm Hole saw. and did all 4.
Drilling Hockey pucks with hole saw
After drilling the puck i assembled them onto the mount body. I used 2 1/2 pucks to replace the swiss cheese mount but used the lower section of the mount in pace of the 3rd puck as i didnt want too much vibration (Dont use lower section for a stiffer mount). The lower section needs the large metal washer removed for use later. A puck is then used to replace the used lower section.
How pucks mount on to body. In total you should use 3 1/2 pucks ( 4 1/2 for stiffer). Pic doesn't show 1/2 a puck in place.
I copper greased the mount body shaft and fitted the pucks.
Showing assembled mount and old swiss cheese mount
Mount was then fitted to car in reverse of removal. The lower puck was fitted to the bottom of the mount with the large washer .
Lower puck mount fitted
I found the engine has a lot less movement now and i can't feel any movement on overrun or accelerating. There is a slight increase in vibration but its acceptable :)
« Last Edit: 08 February 2018, 17:08 by tshirt2k »
Mk3 ABF 16VT Megasquirt V3
Offline VR6_Wherry
Re: HOW TO: Hockey puck front engine mount.
« Reply #1 on: 10 November 2011, 14:21 »
You are a hero!
I always wondered about this mod!
Cheers :afro:
Offline Khare
  • The bear that khares
« Reply #2 on: 10 November 2011, 14:55 »
Nice guide! Will be doing this next time I need to change the front mount  :smiley:
Offline tshirt2k
« Reply #3 on: 10 November 2011, 17:10 »
You can also raise the engine by adding another puck. But you will need to use a longer bolt.
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #4 on: 10 November 2011, 17:12 »
nicely nice
Not no ordinary GTI....
www.mixcloud.com/kells/
billabong
« Reply #5 on: 15 November 2011, 11:26 »
Would you also need to raise the back?
I suppose this is good to prevent smashing your sump if the car is lowered..
Offline tshirt2k
« Reply #6 on: 15 November 2011, 14:04 »
Not sure, maybe. Haven't done it as I'm not that low.
Offline spudboy6
  • Just like a golf ......
« Reply #7 on: 20 October 2012, 09:17 »
how did you split the puck to make half a puck ?
Offline tshirt2k
« Reply #8 on: 20 October 2012, 13:34 »
With a hacksaw.
VW BUSH
« Reply #9 on: 20 October 2012, 15:02 »
What is the hardness of the pucks?
