Author Topic: Help me please!!  (Read 1591 times)
Offline jettaTx
  • Mk1 16v + Mk2 G60 + 309 Goodwood Mi16 + Jetta 16v!
Help me please!!
« on: 02 May 2005, 23:47 »
Does anyone know if a MK2 speedo can be calibrated...
I had some silly red dials so i tought i would take them off in favour of the origionals so i got another dash, swapped all the pins over fitted it all back but now my  speedo is miles out bout 10 mph or what have i done wrong??
Offline Gambit
Re: Help me please!!
« Reply #1 on: 03 May 2005, 10:26 »
there is two speedo drives for VW's. a red one & a white one
red one is for 120 & 160mph clocks
white for 140mph clocks
cost under a £1 from VAG and just snap on the gearbox end of the speedo cable
Offline jettaTx
« Reply #2 on: 05 May 2005, 19:33 »
it seems to be the clocks that are at fault the ones in the car. Any ideas anyone?
Offline Gambit
« Reply #3 on: 06 May 2005, 11:18 »
the clocks cannot be calibrated. just change the speedo drive
Offline hockeylad72
« Reply #4 on: 06 May 2005, 21:27 »
had same sort off problem when I changed my clocks as my mfa was not working, after 3 clock changes the speedo now reads as it should
the clocks can be calibrated around £40.00 from a company calles speedy cables
http://www.speedycables.co.uk/
click FAQ's at bottom of page will give you info on recalibration
but as the others have said make sure you have the correct speedo drive in the gearbox
Offline jettaTx
« Reply #5 on: 06 May 2005, 22:39 »
Thank you hockey lad your info is extremely useful to me i will call them tomorow!!
Its only been since i changed the pin so i assume it will be because of this where my problem lies!
Andy  :smiley:
