Author Topic: connecting to vag-com problem  (Read 15462 times)
Offline (shakey)
  • IS STILL SICK ABOUT CRASHING ME 1.8T AFTER 2 YEARS
« on: 09 November 2011, 10:45 »
right having trouble connecting to vag-com tryed loads of stuff holding the lead in wiggling the lead changing the com port.
plus there is only three wires going into the obd at the back dont know if there is ment to be more  :undecided: its a 1998 tdi 110 non-pd.
Offline (shakey)
Re: connecting to vag-com problem
« Reply #1 on: 09 November 2011, 10:50 »
Offline (shakey)
« Reply #2 on: 09 November 2011, 10:53 »
that was my problem  :grin:
hope you get it sorted bud
 :grin: :grin: simple mistake  :grin: :grin:
cheers pal.
Offline sprout99
« Reply #3 on: 09 November 2011, 11:00 »
cheers pal.
have you done a connection test in VAGcom? to set up correct port?
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline (shakey)
« Reply #4 on: 09 November 2011, 11:05 »
cheers pal.
yep wont connect cant remenber what it said but not having it.
Offline sprout99
« Reply #5 on: 09 November 2011, 11:23 »
is your lead a copy or genuine?
i tried to use a later copy of VAGCOM with my copy 704 lead and it woudln't work.
are your drivers right for the lead you're using.
Oak green mk2
V50 D5 Sportwagon
Offline (shakey)
« Reply #6 on: 09 November 2011, 11:28 »
its a copy off ebay.
so should i redownload the vagcom?
yea think so it was working last week on my 1.8 turbo just not on the tdi i have now.
Offline sprout99
« Reply #7 on: 09 November 2011, 11:33 »
make sure you use the right version for lead - i tried and failed to upgrade !
Oak green mk2
V50 D5 Sportwagon
Offline (shakey)
« Reply #8 on: 09 November 2011, 11:34 »
you got any idea which version i will need ?
Offline rio_gti
« Reply #9 on: 09 November 2011, 14:17 »
have you tried downloadin vcds lite direct from rosstech??
