Author Topic: HELP: First day owning my First GTI, First NIGHTMARE.  (Read 8302 times)
Offline GTI JIMMER
« on: 09 November 2011, 01:28 »
 :cry:
Can't believe it... honestly can't believe it.
Had a look at some MK3 GTIs for the last few weeks...
Thought i had found an absolute beauty! - MK3 GTI 8V
Mystic Blue, great colour, impeccable paint work and great interior, good service history... 5 door, really well looked after, no rust.
£800
The guy put a years MOT on it the on 07/11/11
I went to tax it, then pick it up today 08/11/11
(SUMMARY AT BOTTOM)
30-40 mile drive, was great all the way back, in all gears at the whole range of revs.... i haven't driven in 8 months, so drive steady, but on ring roads give it the beans a couple of times...
Then on a dual carriageway i slowed right down for traffic lights (maybe 10mph?) in the middle lane (always the way) and the car just cuts out on me (or i was in gear, not on the clutch therefore stalled?)!! try and start the car again, nothing happens... sat in the middle of the road looking like a right muppet, my mate in the car with me with his arm in a sling (cant push) police came, pushed me to layby...
My mate came, helped my push it to McDonalds...
First thing first - Petrol, filled up jerry can (petrol pump number 13  :undecided: tried to fill it to £5... landed on £5.01  :undecided:
Poured it in, still wouldn't start... Ok, my dad brings leads, try the jump start it, still doesn't work!
Another mate came down (i've been sat in McD's car park for 3 hours, FUNTIMES.) Hes a mechanic, family friend, really helpful he checks spark plug, no spark... (which are new, as are HT leads). I'm in contact with the seller throughout who sounds genuinely gutted and is a decent bloke.
Both say dizzy cap and rota arm havent been changed in a while - so yeah lets go for it, Halfrauds....
Put on dizzy cap and rota arm, get spark, still won't start!
Petrol fumes from back of the car, my mate tells me its not fuel thats the problem...
The engine is trying to turn over!!!
Another factor - Cobra immobiliser, 9 years old... Seller tells me he doesnt know much about it, (i played around with the fob when i was waiting for help) me and my mate have a look at the cobra alarm guides etc online, and we try and disarm the alarm with the card they give you, (you have to turn ignition a certain number of times) but the first stage of the process doesn't work, so there IS a fault with the Immobiliser.
I left my car in McD's, they didn't mind... so i now need to call out a cobra technician... Any chance this will mean i can drive away?! or will it just mean i now have a working immobiliser but still no working car :\
SUMMARY:
I was slowing down to 10mph. Car died on me, or i stalled??.
Either way, i couldn't restart the car.
The car has had:
New cambelt
1 year old battery (4 year battery life)
New HP leads
New spark plugs
Filled it with petrol... still no joy. (friend arrives with tools, and mechanic skills)
Had no spark... but engine tries to start, turns over!
changed dizzy cap and rota arm
Had some spark!
. exhaust smells of petrol, my mechanic friend tells me he thinks petrol is fine..
Immobiliser is of an unknown quantity, i played with it as i was sat the car waiting for help... maybe messing it up? meaning that the new dizzy cap and rota arm were fixed, and the car would be fine with immobiliser sorted?
So... we try to disarm the immobiliser using the pin number, but do not even get to the stage of the immobiliser light (on top of the dash) responding. (turn ignition on/off 3 times within 7 seconds... then light should flash 3 times)
Doesn't work...
Going to call a technician in the morning and pray that he can get it sorted (if not, that the call out charge isn't too steep!)
Help? :cry: if you can't help, i hope my misery mildly amused you  :tongue:
Offline Seanl
Re: HELP: First day owning my First GTI, First NIGHTMARE.
« Reply #1 on: 09 November 2011, 07:04 »
Doubt it would be the immob whilst driving. My guess would be crank sensor or ignition switch. Have a search as it happens loads mate.
Offline stainesy
« Reply #2 on: 09 November 2011, 08:05 »
Try replacing the coil.
Offline sharki786
  • GOT BOOST??
« Reply #3 on: 09 November 2011, 10:00 »
thinking the same myself. if no spark but engine is turning over then its got to be the coil pack £50-£60 new
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline kahunajb
« Reply #4 on: 09 November 2011, 10:05 »
But the OP is saying he is getting a spark.  :undecided:
OP are you definitely now getting a spark as it does sound like your coil?
Mk1 Leon Cupra TDI - Keeping
Mk5 Golf GTI - Revo Stage 1 - FOR SALE £5,250
Mk3 GTI 16v Anniversary - OEM+ - Gone :(
Mk4 GTI 2.0 - Slow - Good Riddance
Offline B1rd1e9
« Reply #5 on: 09 November 2011, 10:07 »
i feel your pain i had a gti 8v thought i had a beauty then gear box went  :cry: swapped it on a site for a diesel told lad what was wrong with mine was happy enough to swap now my diesel is struggling to start was going to put a non return valve on it but looks like previous owner has already done that cheeky twit  :angry: next step im thinking new glow plugs? my dad seems to think thats not the problem and thinks its more injectors/air leak
Offline dragongreengolfgti
  • my golf gti mk3
« Reply #6 on: 09 November 2011, 10:40 »
sounds ignition  related to me most likely coil pack or ignition  barrel itself as already said give it a wiggle while ttrying to start it
Offline GTI JIMMER
« Reply #7 on: 09 November 2011, 10:52 »
Ok, thanks a lot everyone!!!
I heard that if it is the coil, WD40 could be used to test it?
Yeah i'm so gutted, had its MOT two days ago as well  :undecided:
called up an electro- technician guy, im sure he will have some kind of solution,
I will give pass on all relevant information,
Will get back to you all!!
Offline stainesy
« Reply #8 on: 09 November 2011, 11:11 »
On my old mk3 1.8 gl I had a problem with imob key sensor thingy behind ignition barrel.
It did not pick up the chip in the key. I had to take off plastic steering wheel surround and move a wire up closer to end of ignition barrel so it could pic up the key chip better and it solved it.
« Last Edit: 09 November 2011, 11:16 by stainesy »
Offline GTI JIMMER
« Reply #9 on: 09 November 2011, 15:52 »
Guy came out, told me that the immobiliser had already been by-passed.
 He then set about trying to find out why the car wasn't starting...
He tried his diagnostic tool, but said he couldn't get onto the ecu...
Told me that could be the issue, the car is now outside my house so i might try and get to the ecu...
He advised me to take it out, and see what condition it is in.
(Think i will have a look with my mate tonight.)
The previous owner text me, told me that the coil wasn't new, just the coil leads... He's convinced that its something small.
Hopefully it is the coil, as alot of you on here have suggested it?
The guy said the spark was intermittent, and weak to 2 of the spark plugs...
Does this still sound like the coil?
Might try buy a new coil today, hopefully does the trick!!!
Where could i get a coil? Just a standard halfrauds? or something more specific like euro car parts?
All in all, today the call out and checks on my car, and the cost of the car being taken back to my house has come to £173
Fun.
