Author Topic: Help is this a massive problem.... bloody hope not!  (Read 3807 times)
Offline kniterider
  • had most, sold most and often buy more!
Re: Help is this a massive problem.... bloody hope not!
« Reply #10 on: 02 May 2005, 21:01 »
if it is like we think the filter seal, it will only leak whilst the engine is running.....
so crank it up and watch...
 :smiley:
Offline SarahD
« Reply #11 on: 02 May 2005, 21:07 »
heres some pics of the oil filter and crossmember
Offline kniterider
« Reply #12 on: 02 May 2005, 21:25 »
deffo looking oil filter area.... lets hope its a cheap fix hun!!
 :laugh:
Offline SarahD
« Reply #13 on: 02 May 2005, 21:32 »
hope so  :cry:
Offline Agreeable Slick
  • Unit
« Reply #14 on: 02 May 2005, 22:32 »
tried replacing the oil pressure switch on the top of the oil filter housing, It's hard to spot but mine went on the old white valver and i had no idea where it was coming from until i put it on a ramp and prodded about all around the oil filter, then bingo there it was dribbling oil everywhere.
Might be worth a look, if it is they cost about £3 from GSF and take all of 5 mins to replace.
Offline *Dubby*
« Reply #15 on: 02 May 2005, 22:34 »
yep, pitstop pointed that out to me as a common place for oil to piss out of  :undecided:
Jeeeeeeeeeeeeeeeeeeeeeeeeep
Offline Gambit
« Reply #16 on: 03 May 2005, 11:04 »
aye just squeeze the wee rubber boot on top of the senders, if oil is coming out of them then the wee boot will be full of oil
i recently replaced the gaskets on my oil filter. pretty easy enough. there is a gasket for the oil filter housing and also a gasket/ rubber o-ring that goes between the filter housing and oil cooler - got both from German Swedish
Offline SarahD
« Reply #17 on: 03 May 2005, 12:52 »
ive had a good look today and its leaking from the oil filter. ive just bought a new one am takin it to jet wash to blast all the oil off from underneath and im gunna change the oil and filter and hopefully *fingers crossed* itl be fine  :cool:
Offline monkeyalan
« Reply #18 on: 03 May 2005, 13:01 »
don't forget to take some WD40 if your sparying water near any electric bits. Hope it works out, i don't think you need anymore bad luck :wink:
Offline davero
« Reply #19 on: 03 May 2005, 13:39 »
best off luck with that sassy, hope it  is just filter :sad:
