Author Topic: holding back?  (Read 3094 times)
Offline darren1.8t
  • I HATE FRENCH CARS
holding back?
« on: 08 November 2011, 08:40 »
hi guys my bora 115 tdi has been mapped but at 3000rpm it holds back? unless i feed the throttle? i put a new airflow on her and there are no fault codes now? also the turbo sounds very whistley if you no what i mean??? i cleaned the egr out and noticed the manifold was sooted up!! could it be that causing the holding back or could it be the turbo?
Offline sprout99
Re: holding back?
« Reply #1 on: 08 November 2011, 15:12 »
it could be the map you got
25th Anniversary TDi - PD
Oak green mk2
V50 D5 Sportwagon
Offline darren1.8t
Re: holding back?
« Reply #2 on: 08 November 2011, 19:22 »
i did think that mate its a revo map my mate had it done? but the turbo sounds really loud?? but boosts fine?
Offline sprout99
Re: holding back?
« Reply #3 on: 09 November 2011, 08:33 »
mine had a map on when i bought it - lad said his 'mate' did it
it was ok-ish but not great. seemed to be a delayed power shunt when accelerating.
so did some logging on it - found out it was really bad so got it changed - boost was spiking and fuel was turned up across whole rev range to max.
now i run a very smooth upsolute map. Took 3 versions to get it how it is now. I don't like a massive kick of torque
prefer the more linear delivery
Oak green mk2
V50 D5 Sportwagon
Offline Rhyso
Re: holding back?
« Reply #4 on: 09 November 2011, 08:35 »
If your turbo is getting louder then it could be on its way out  :undecided:
Get the TIP off and try and check for any play in the shaft.  Catch it now and you'll save yourself a couple hundred quid in rebuilding the turbo
Get the pipework checked out for boost leaks too; you might have a split which only opens up under full load
Offline darren1.8t
Re: holding back?
« Reply #5 on: 10 November 2011, 06:16 »
cheers lads not sure what do do i have changed all the pipe work maybe the turbo its way?
