Author Topic: swapping engines  (Read 4497 times)
Offline (shakey)
  • IS STILL SICK ABOUT CRASHING ME 1.8T AFTER 2 YEARS
swapping engines
« on: 08 November 2011, 08:35 »
ok
thinking of swapping engines with my mums sharan if it fits.
its an auto and my is a manual so will it fit plus would i need the ecu and what other bits do i need and so on.
cheers
Offline EsSeX dAn
Re: swapping engines
« Reply #1 on: 08 November 2011, 13:14 »
it depends on engine codes,if theyre both pd or non pd engines aswell. the engine should physically fit and you should be able to just swap the gear box and clutch over. possibly flywheel too but im sure someone will correct me on that. also possibly manifolds may differ but again in not 100%
i think i love you.....
Offline Steve_PD
« Reply #2 on: 08 November 2011, 16:53 »
it would be a massive job
Offline (shakey)
« Reply #3 on: 08 November 2011, 18:18 »
sod that then will went till mine goes bang only thought about it because its got low miles
