Golf mk2
dizzy stuck
Topic: dizzy stuck (Read 2131 times)
herr schimdt
dizzy stuck
07 November 2011, 18:00 »
got a mk2 gti that has had extensive work done to it before i bought now im just trying to sort out the bodges it ticks over rough so tried to adjust the ignition timing as its quite a bit out got my timing light all set up undid the nut on the distributor tried to turn the distributor but it wouldnt budge took the clamp completly off and looked at the bottom of the dizzy and it looks like some one has allready tried to adjust it with a chisel and hammer so must be well stuck now what i want to know is what sort of dizzy and block do i have was told it is out of a mk3 2.0 gti with a mk2 gti head but cant find any markings on the block or dizzy
hopfully dont need to get a new bottom end
Bigdunc
Here all the time
Re: dizzy stuck
07 November 2011, 20:09 »
could try the freeze and release spray
mad4vws
Re: dizzy stuck
07 November 2011, 20:16 »
the dizzy in the picture seems to be in the wrong position ,the connector should be in the middle and not close to the engine or bell-housing.
BREAKING VW GOLF'S
Mk2/ MK3'S ALL DAY LONG. PM FOR ANY PARTS!! ON 07813936583
herr schimdt
Re: dizzy stuck
07 November 2011, 20:47 »
thanks ill try getting it out tomorrow and se if i can get it set up right cheers
Bigdunc
Here all the time
Re: dizzy stuck
07 November 2011, 21:10 »
yes if timing on the belt is set correctly the dizzy position is quite far out, and i think the dizzys lift out rather that twist out so if you have a timing light you could possible wiggle it up and down.
jmsheahan
Re: dizzy stuck
07 November 2011, 22:56 »
Looks like a 2E/AGG 2.0 lump as you say from a mk3 judging by the breathers. It should be stamped just above the block breather but bit strange it's blank there
herr schimdt
Re: dizzy stuck
Reply #6 on:
08 November 2011, 08:47 »
Yeh its suposed to have an engine number the engine has aparently been rebuilt 4000 miles ago with new piston rings reground crank new bearings big and little ends piper cam polished and ported head bigger valves it feels a real strong engine and its fast as fook but the block is well rusty and like some one painted it with house hold gloss and all the ancilleries look old so needs some tidying up
the car has apparently had a full respray to but looks a diferrent shade on front wings
think it was built bye John Wayne
herr schimdt
Re: dizzy stuck
Reply #7 on:
08 November 2011, 17:03 »
thanks for the help guys pulled out the dizzy turned it round set it up bye eye replaced the blue temp sensor £19 from the stealers runs sweet now just need to get it set with the strobe and get a new dizzy cap and rotor and ill be laughing
Bigdunc
Here all the time
Re: dizzy stuck
Reply #8 on:
08 November 2011, 19:06 »
Win
Golf mk2
dizzy stuck
