Author Topic: Mk3 GTI Advise needed!  (Read 3304 times)
Offline Scottydog89
« on: 06 November 2011, 21:48 »
Hi All,
I am currently looking for a decent Mk3 GTI for less than £1500 with around 80,000 miles on the clock to run as my main car for a year or so while I save some money to buy a nearly new GTI or Scirocco.
I have seen this one, http://www.pistonheads.com/sales/3372388.htm
What should I look for when I view this car or one like it? I know the usual things, but is there anything in particular these cars suffer from?
Any other advise would be appreciated!  :laugh:
Scott
Offline dom
  • Back in a Mk4
Re: Mk3 GTI Advise needed!
« Reply #1 on: 06 November 2011, 21:51 »
Biggest thing to check for it rust....everywhere!
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #2 on: 06 November 2011, 22:08 »
Rust under the plastic wheel arches and sill covers, area where the door seals join together at the bottom, bottom of the doors on the inside. Water under the carpets. Paying that kind of money it essentially needs to have no rust and a Mk3 can hide it all well.
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #3 on: 06 November 2011, 22:14 »
looks ok, might be just the pic but the grill does not look like a GTI item
Not no ordinary GTI....
www.mixcloud.com/kells/
« Reply #4 on: 06 November 2011, 22:18 »
Looks ok but haggle a little more also as Brad said that is not a GTI grill
Offline Deano2711
  • 1992 VR6
« Reply #5 on: 06 November 2011, 22:32 »
I have been looking around the Bay and other forums this weekend and there are similar examples just as clean looking for less money. With your budget I personally would be looking towards something more desirable like a Colour Concept or Anni if you're looking for the 8v GTI.
Offline stainesy
« Reply #6 on: 07 November 2011, 09:42 »
Also look around the engine bay for any accident damage. Seeing as the grill has been replaced you should ask why.
Offline tdi_blu
  • Golf Gti & T4 2.5 tdi
« Reply #7 on: 07 November 2011, 10:00 »
As already said rust open the tail gate check where the loom comes through they bubble bad there,lower quarter of the front wings,feel the arches as its hard if they have a arch kit on.Check the drainage bungs in the floor give them a poke usually always rust and then look at the sills near the front where gimps have used a trolly jack make sure the sills are not crushed in also check where you put the fuel in.Check the abs light and airbag light come on and go off if they dont light up at all someones pulled the plug.To be honest the rust is the main thing really as most other things are a simple fix I always reverse a car aswell as mk3s can suffer with gearbox issues but good luck in finding one if you do find a decent one there good motors..
Golf Gti
Offline Scottydog89
« Reply #8 on: 07 November 2011, 17:19 »
Thanks you all for your advise so far, keep it coming!
Also, if anyone can send links to similar cars they have seen in the Essex area that would be great  :grin:
Offline madmanmart
« Reply #9 on: 07 November 2011, 17:30 »
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
