Author Topic: Mk3 AGG 8v wont start following throttle body and distributor clean  (Read 10344 times)
Offline Adezmk3
Hi,
Basically my 8v AGG won't start following having the cut out problem and not revving past 5000rpm.
I removed the throttle body which was caked in black grime and cleaned that thoroughly, then reassembled it.
I then foolishly got carried away and thought spraying some contact cleaner through the dizzy wouldn't be a bad idea (without seeing if the throttle body clean had worked) as the 5000rpm limiter has occasionally not happened so I assumed it could just be dirty in the distributor. Now the car wont start and I don't know if that is a result of the throttle body clean, or the dizzy.
When turning the engine over I can smell fuel and upon checking the plugs they are getting wet with petrol.
I checked I was still getting a spark which I am, but have no way of telling if its sparking in time.
I have now changed the dizzy cap and plugs and the car still won't start.
Any suggestions? I'm betting on the dizzy being at fault. Does anyone know where I can buy a recon or replacement one that isn't £110 like from VW?
Offline Len
Why did you spray the dizzy?
Get a hair dryer on that and try again.
Failing that try the coil
www.sas.org.uk
www.the-ace.org.uk
Offline Adezmk3
Thanks for your response, The reason I have cleaned up the dizzy was because on a couple of occasions the car has revved over 5000rpm, so I cleaned the distributor out to rule out dirt as the 5000rpm culprit. I have had the electrical engineers at work test it and they said the hall sensor is fine, so my fault must be wiring related, although I do have a spark when the plugs are out, but the plugs get soaked in fuel when they are in...
I have found the breather tube is damaged from the front of the engine to the flying saucer, but sealing that up has made no difference.
Thanks,
Adrian
Offline Adezmk3
Anyone know what a flashing oil light symbol means? Is that an indication of an electrical fault or something??
Offline sharki786
  • GOT BOOST??
low on oil.
like len said try the coil pack
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Adezmk3
This flashing oil light I didn't think was a 'low on oil', theres plenty in the engine and it randomly does it after attempting start up
Offline patc
I solved my similar problem by changing, in this order:
Coil pack
Dizzy cap (eBay £11)
Plugs
Leads
Crank sensor
ECU relay
Fuel pump relay
The winner seemed to be the 2 relays as its been faultless since, although the crank sensor needed doing anyway as it was shot!
PatC
Golf GTI MK3 Anniversary Edition
Offline todd
Is it fixed now if so what was the problem ?
« Last Edit: 05 February 2012, 22:16 by todd »
