Author Topic: Mk3 2.0 8v wont start following throttle body and distributor clean  (Read 4358 times)
Offline Adezmk3
Thanks for the link, my engine cranks over fine, just doesn't fire up, has fuel and spark so I am assuming its either fueling so much the fuel isnt igniting, the sparks in completely the wrong time in the cycle, both, or the sparks not happening when the plugs are actually in.
I would expect to hear at least one misfire though....
Offline javalin
would assume that the dizzy is mis-aligned, but you've checked that....?
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
