Author Topic: 1.4 aex with mayo in oil cap  (Read 2333 times)
Offline dubpirate
« on: 06 November 2011, 17:38 »
right guys iv had my golf 3 for about 3 weeks
great car
just looked under the oil cap tody and its packed with mayo it wasnt there when i bought the car
i do reasonably short jurneys everyday
but do an average of 150 miles a week
there is no mayo or crud in the expansion bottle
the temp is always fine no problems never goes over half
the engine has only done 64k
should i be preparing for headgasket
or would a good service  cure the problem
thanks dan
Offline tweed
Re: 1.4 aex with mayo in oil cap
« Reply #1 on: 06 November 2011, 17:49 »
you can wipe the mayo off  :cry: seller most likely did this and most likely why he sold the car.
mayo can be a couple of things but most the time it's headgasket.
Get a compression test done and if one or two cylinders is down then I would suggest headgasket
Offline madmanmart
« Reply #2 on: 06 November 2011, 18:02 »
Mayo with an AEX is fine, especially with short journeys.
Mine had it when it had 30k miles on the clock...... :tongue:
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline tweed
« Reply #3 on: 06 November 2011, 18:08 »
a lot of mayo and 150 miles a week?
a little mayo is fine, my vr6 has a little bit now and then.
Offline madmanmart
« Reply #4 on: 06 November 2011, 19:29 »
Ive just bought a mk4 polo for the misses, it also has an AEX.
It also has quite alot of mayo and we owned it two weeks.
I'd bet my car that its fine.......... :wink:
Offline tweed
« Reply #5 on: 06 November 2011, 20:55 »
cool i'll keep this in mind  :smiley:
Offline CJA321
« Reply #6 on: 06 November 2011, 21:17 »
Mayo is quite often condensation and mixxes oil and water at top end. seen it seize tappets before on astra 8v. which its so common for doing on those engines. if your that bothered put a good engine flush through and replace oil and filter. as mentioned before could allso be head gasket. but it would be running pritty crappy tbh if that was the case. also exp bottle would most likely be creamy too
« Reply #7 on: 07 November 2011, 13:46 »
Just keep an eye on it and see if it comes back.
Offline AudiA8Quattro
« Reply #8 on: 07 November 2011, 16:45 »
Short trips cause it, but also some oils can be prone to it.
Try changing the oil for a good quality semi synthetic and take the car for a decent run.
Offline LazyLunatic
  • MK3 20VT Project
« Reply #9 on: 08 November 2011, 18:29 »
My bottom end went with the same symptoms, maybe I was just unlucky.
So I did this :D
http://www.youtube.com/watch?v=Qp3oEVv2PUY
