Author Topic: car wont start. help please  (Read 9646 times)
Offline NERF 69
Re: car wont start. help please
« Reply #70 on: 20 November 2011, 22:42 »
Gonna change the relays next the guy who looked at my car said he had a similar problem with his corrado and it was his relay 72. Its definately not the fuel relay i took the fuel line off and turned the engine and it pissed everywhere
Sell my Vw??? I'd rather stick wasps up my arse
Offline Leon27
« Reply #71 on: 20 November 2011, 23:16 »
Corrado relay no.72 could be different to a Mk3 relay 72. Saying that because:
http://www.golfgtiforum.co.uk/index.php?topic=74087.0
Relay 72 is for the rear wash/wipe function.
Have you had the car scanned for faults? If nothing comes up I'd definately do what harlemex said and get a compression test done.
Few things though, you said intially your fuel consumption halved and the car felt flat... Skipped timing could cause that.
Then the spark sequence wasn't correct, again, cam (dizzy) to crankshaft correlation could be out giving that fault.
Get a compression test done as said or simply just check the timing marks are all in place.
If all is ok, even after changing your relays, check over all the new parts that you have bought. You mentioned a weak orange spark, it should be bright white/blue colour indicating high resistance through a faulty part?
Hope you nail this  :smiley:
Offline patc
« Reply #72 on: 21 November 2011, 08:51 »
Relays 30 & 167. For the sake of just £10 each and 5 mins to do, it's the most obvious choice before larger expense.
PatC
Golf GTI MK3 Anniversary Edition
Offline NERF 69
« Reply #73 on: 22 November 2011, 22:41 »
Faulty car + diagnostics machine = no faults :huh:
Offline patc
« Reply #74 on: 23 November 2011, 11:39 »
Done the cheap obvious relays yet!?
PatC
Offline NERF 69
« Reply #75 on: 23 November 2011, 12:36 »
No thats todays job really hope it works
Offline NERF 69
« Reply #76 on: 23 November 2011, 18:12 »
Found me a relay. £11 from europarts picking it up in the morning. Fingers crossed :undecided:
Offline patc
« Reply #77 on: 23 November 2011, 19:09 »
"a" relay?  Not both?
PatC
Offline NERF 69
« Reply #78 on: 23 November 2011, 19:18 »
Didnt bother with the fuel relay as im getting plenty of it.
Offline NERF 69
« Reply #79 on: 25 November 2011, 10:51 »
Relay replaced all earths checked and yet again still nothing and a flashing oil light
