Author Topic: car wont start. help please  (Read 9661 times)
Offline Seanl
Re: car wont start. help please
« Reply #60 on: 20 November 2011, 16:12 »
Yep relays should have been one of the first to replace as their cheap and easy to do.
Offline NERF 69
« Reply #61 on: 20 November 2011, 18:54 »
Just had a mate round how know his sh!t with vdubs and hes found it has a spark when i turn the ignition on (not when i turn it over). Apperently thats not supposed to happen so hes advised me to change relays 30, 72 and 99
Sell my Vw??? I'd rather stick wasps up my arse
Offline harlemex
« Reply #62 on: 20 November 2011, 19:01 »
worth a try but I dont think its your problem...
Offline NERF 69
« Reply #63 on: 20 November 2011, 19:10 »
Would you suggest anything?
Offline harlemex
« Reply #64 on: 20 November 2011, 19:39 »
New plugs?? since you have been to the length of changing most of the other ignition components, do this.
Offline NERF 69
« Reply #65 on: 20 November 2011, 20:45 »
I've already changed the plugs so its not them
Offline harlemex
« Reply #66 on: 20 November 2011, 20:52 »
well why didnt you say???  :laugh: Compression test needed.
Offline NERF 69
« Reply #67 on: 20 November 2011, 21:24 »
Had to manually turn the engine when I changed the dizzy and it took some shifting but its obviously not a compression test
Offline Seanl
« Reply #68 on: 20 November 2011, 21:27 »
As said, start with relays. ECU and fuel pump relays - 30 being one of em, but I cant remember the other. They are about £12 I think, so should really have been one of the first things to be replaced being so common and so cheap to replace.  :smiley:
Offline Screech16v
  • MK3 20vt AGU
« Reply #69 on: 20 November 2011, 22:20 »
Cmon this ^ you aint lost much if it isnt the prob,sean the other one your thinkin is 167 i think :tongue:
