Author Topic: 16v locking flywheel  (Read 1133 times)
Offline golfmk4owner
« on: 05 November 2011, 13:09 »
Guys im timing my KR 16v gti, everytime i tension the belt the flywheel mark moves out a few degrees. How bad would this be? If its bad, how do i lock my flywheel i cant see and holes
Cheers. Sorry if its somewhere else, difficult to search im cocvered in oil
2005 GT TDI 140 - Standard as F@k
Offline danny_p
Re: 16v locking flywheel
« Reply #1 on: 05 November 2011, 21:34 »
i've never had to lock the flywheel,  just pull the belt tight ish to the cam then pull the cams forward a littel  with a spanner so the teeth line up then when the tenstion is taken up the timeing marks should be spot on
all the VW's have gone bar 1.
