Author Topic: Knocking/Banging noise rear suspension ?  (Read 20920 times)
Offline Neil gti
« on: 05 November 2011, 09:50 »
Had the car in yesterday to investigate the knocking noise from the rear passenger side that i have been hearing for the last couple of weeks,
After a good look around and removing wheels, springs, shocks, spring cups etc and refitting all to try and eliminate this noise,
Test drive time and the noise is still there  :angry:
I have had a search around the different forums and not come up with much apart from spring cups and rear axle bushes, ?
Any ideas  :smiley: Answers on a postcard please  :wink:
Mk6 Gti Gone but not forgtten
Loving the 7R
Offline Awry
Re: Knocking/Banging noise rear suspension ?
« Reply #1 on: 05 November 2011, 10:13 »
I've heard of this problem but this was on the front due the arm in the picture below not being tightened properly.
Reflex Silver MK6 GTI 3-door DSG, DCC, Sunroof, 18" Detroit, Xenons, LED tail lights, RCD 510, Dynaudio, Media-in, Bluetooth, Cruise Control, Winter Pack.
Added Milltek 3" Race exhaust and H&R suspension.
Offline Neil gti
« Reply #2 on: 05 November 2011, 10:29 »
Thanx Awry,
Everything was checked for tightness incl droplinks at rear  :sad:
I was wondering if the stretch bolts was replaced in the front subframe when i had my anti roll bars replaced, the noise sounds like it is coming from the rear, but noises can travel and hard to pinpoint ? will ask them on Monday
Loving the 7R
Offline Neil gti
« Reply #3 on: 05 November 2011, 10:36 »
Loving the 7R
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #4 on: 05 November 2011, 15:16 »
Im sure i remember a rear passenger side suspension problem that effected the mk5's but i cannot find it. :undecided:
The reason i originally looked for it was mine bangs on the passenger side rear when im in it alone but i think its more down to poor door catch adjustment on the rear passenger door due to mine been a 5 door were yours is a 3 as mine does not do it if theres someone in the back of the car on that side.
Current Garage:
35+ years of GTI ownership.
« Reply #5 on: 05 November 2011, 15:38 »
Those ball things on the end of the parcel shelf strings are a favourite for casuing mysterious knocking sounds from the arse end.
Exhausts hitting ARBs are another cause of noises.
These things drive you nuts when it's not an obvious cause ....
Offline Neil gti
« Reply #6 on: 07 November 2011, 18:45 »
Problem sorted
Put the standard shocks back on the rear today and no more banging/knocking noise,  :rolleyes:
Think it could be the bottom bushes in the KWs ?
Loving the 7R
Offline Awry
« Reply #7 on: 07 November 2011, 22:56 »
Great. Glad you found the source of the problem. :)
Is it the KW DCC you have? I'm considering them.
Offline Neil gti
« Reply #8 on: 08 November 2011, 06:20 »
Awry,
It is the KW V3s i have fitted, May look at getting the clubsports or look at something else like the ASTs from VWR ?
Loving the 7R
Offline Awry
« Reply #9 on: 08 November 2011, 06:49 »
Awry,
Do they support DCC as well?
These are the ones I was looking at -> http://www.kw-suspensions.eu/int/kw_ddc.php
