Author Topic: Airbox  (Read 2242 times)
Offline Milby
Airbox
« on: 04 November 2011, 19:09 »
On my 1.4 it has a airbox on top of the engine and I want to put a short ram intake or something similar instead for cosmetic reasons and for a better sound but all the ones i found are for engines with with separate air boxes like on the bigger engined golfs. So how easy is a custom and how would i go round making and fitting it :) or does anyone know of a kit available ??
MK3 Golf 1.4 SE ;)
Offline dom
  • Back in a Mk4
Re: Airbox
« Reply #1 on: 04 November 2011, 19:23 »
You already have a cone filter :huh:
Offline Milby
Re: Airbox
« Reply #2 on: 04 November 2011, 19:25 »
yeh :) i wanted to have an induction kit which means i can get rid of airbox is this possible or should i leave it standard ??
MK3 Golf 1.4 SE ;)
Offline LowlifeDubber
Re: Airbox
« Reply #3 on: 04 November 2011, 19:55 »
Do you now have 2 air filters on your car? :grin:
Offline Khare
  • The bear that khares
Re: Airbox
« Reply #4 on: 05 November 2011, 20:46 »
If you have two filters then major fail. Major. Does it even sound louder with the induction kit there? The airbox is what quietens the engine down, and you've still got it fitted...oh and you'd have lost power from having the filter there, its sucking in hot air  :smiley:
« Last Edit: 06 November 2011, 04:02 by Khare »
Offline Milby
Re: Airbox
« Reply #5 on: 06 November 2011, 07:15 »
i need something to put in to replace the airbox is there anything available
MK3 Golf 1.4 SE ;)
Offline kylepeo
  • Vw's never die they just get lower !!
Re: Airbox
« Reply #6 on: 06 November 2011, 12:20 »
only thing i would replace that air box with would be a 2l 16v  :grin:
Vw\'s never die they just get lower !! :):)
Offline Milby
Re: Airbox
« Reply #7 on: 06 November 2011, 12:47 »
i wish haha
this is a pic of airbox removed could i just put a silicone pipe from where the butterfly valve is down to bottom of engine bay with filter on end and then have separate small filter for oil ??
MK3 Golf 1.4 SE ;)
Offline dom
  • Back in a Mk4
Re: Airbox
« Reply #8 on: 06 November 2011, 13:08 »
Just to clarify, is there currently an air filter inside your air box as well as the cone filter or is the airbox empty? :huh:
Offline Milby
Re: Airbox
« Reply #9 on: 06 November 2011, 13:10 »
just took external filter off and replaced filter inside box :) originally had no filter in box just external filter :)
MK3 Golf 1.4 SE ;)
