Author Topic: removing top nut on struts  (Read 3314 times)
Offline dubpirate
« on: 04 November 2011, 19:09 »
obv 7mm allen key (brake calliper key)
whats the ring spanner called i need
going to go buy one 2morra morning
is it like a 21mm deep spanner ??
exact name needed guys
cheers dan
Offline Seanl
Re: removing top nut on struts
« Reply #1 on: 04 November 2011, 19:50 »
Offset spanner. Not sure if it will be deep enough to get a good purchase on the nut over the side of the topmount though, but dont quote me on that as I've not tried.
Offline Dan_GTi8v
« Reply #2 on: 04 November 2011, 19:53 »
21-22 mm swan neck ring spanner.
Offline mad4vws
« Reply #3 on: 04 November 2011, 20:20 »
you could use a spark-plug socket  as most have a 22 or 24 mm head on them and a 7mm Allen key . :smug: :smiley:
« Last Edit: 05 November 2011, 15:46 by mad4vws »
BREAKING VW GOLF'S
Mk2/ MK3'S ALL DAY LONG. PM FOR ANY PARTS!!  ON 07813936583
Offline snifferdog
« Reply #4 on: 04 November 2011, 20:48 »
It was a proper pain in the arse when I did it. I bought a special tool from halfords that seemed to do the trick.
Beware though - I also bought a deep offset ring spanner but it wasnt deep enough!
Offline Junior74
« Reply #5 on: 04 November 2011, 21:37 »
I always use a spark plug socket and a funky allen key with a rubber handle from halfrauds.
Offline CJA321
« Reply #6 on: 04 November 2011, 21:41 »
Did mine today after work. love having an impact gun and endless use of the of the compressor at work  :laugh:
You could put a pair of vice grips on the shocker shaft and use a 21mm socket and racthet btw. rough but it works!!!! Just jam the vice grips when the shaft turns.
Offline Deano2711
  • 1992 VR6
« Reply #7 on: 04 November 2011, 21:43 »
Just nip down to your local tyre bay and they will undo them with the air gun and then go back later to tighten them. Worth a few beer tokens to save so much time  :wink:
Offline CJA321
« Reply #8 on: 04 November 2011, 21:59 »
Yeah that would work... but he would have to drive home with no top mounts on that hold the strut to the chassis  :tongue:
Offline AudiA8Quattro
« Reply #9 on: 04 November 2011, 22:18 »
I do hope you're not suggesting driving the car with the nuts cracked off?
As already suggested, the best way to loosen them is with a spark plug socket and an allen key.
