Author Topic: My carbonated GTD - with dyno plots  (Read 7335 times)
Offline The Doc
  • E63s Estate - Vito Sport
Re: My GTD has been carbonated - with dyno plots
« Reply #20 on: 06 November 2011, 11:33 »
The traffic light shoot out is very much of a muchness in a GTI vs remapped GTD but when they are both remapped the GTI is much faster.
« Last Edit: 06 November 2011, 14:06 by The Doc »
Offline am1w
« Reply #21 on: 06 November 2011, 13:02 »
 :grin: :grin:
The traffic light shoot out is very much of a muchness in a GTI vs remapped GTD but when they are butt remapped the GTI is much faster.
Doc, your talents are amazing!
Offline Hurdy
« Reply #22 on: 06 November 2011, 22:40 »
You aren't trying hard enough Herr Doktore  :tongue:
I'm at 221bhp and 232lbft from my mini-me 1.4 GTI.  :wink:
Your torque is however, very impressive.  :embarassed:
Get that DPF off pronto.  :grin:
Great to see that Carbon is doing well and turning out good tuning results. I may have to pop down and see you sometime.  :cool:
Seat Leon Cupra Black 290 DSG
Offline R32UK
« Reply #23 on: 07 November 2011, 07:38 »
Is the DPF on all of the 170 Diesel golfs? What effect does removing this have on both performance + other factors such as mot/economy/emissions if any??
Offline Rhyso
« Reply #24 on: 07 November 2011, 09:54 »
They are fitted to ALL the 170's; that includes the older PD engines like mine and the newer CR engines like Craig's
Removing the DPF free's up anywhere between 5-15bhp and a few lbs ft of torque.  MPG is also said to improve.
AFAIK the MOT is changing next year so any car manufactured from a certain point in 2008 MUST have the DPF in place otherwise it will be an instant fail......
Offline R32UK
« Reply #25 on: 07 November 2011, 11:32 »
Thanks!  :smiley:
So a pre 2008 GTTDi 170 is quite desirable then I imagine...  :undecided:
Offline Rhyso
« Reply #26 on: 07 November 2011, 11:45 »
Thanks!  :smiley:
Could well be   :undecided:
Offline mortygt140
« Reply #27 on: 07 November 2011, 17:01 »
Rhyso is the DPF like the CAT with the honeycombe centre :undecided: how does it work? If it is like the CAT then can it be opened and knocked out to make it straight through.
Darren
Offline The Doc
« Reply #28 on: 07 November 2011, 17:32 »
Darren
Yes it is but we sell lovely bypass pipes that help the exhaust gasses flow better  :wink:
Also you can put you dpf back on if required in future if needs be  :wink:
Offline Rhyso
« Reply #29 on: 07 November 2011, 19:24 »
Darren
What he said ^^^^^
I never understand those who simply remove the guts of the DPF  :undecided:  At some points in the pipe work around the DPF you're looking at only an inch in bore size  :shocked: :shocked:
A true DPF delete pipe gives the best gains  :evil:
