Author Topic: shammies  (Read 4364 times)
Offline Dizzie
  • Make friends with your fast
shammies
« on: 01 May 2005, 18:29 »
how do you clean them?
kingsmk2
Re: shammies
« Reply #1 on: 01 May 2005, 18:50 »
what i tend to do is leave them on a bowl of water with a little flash liquid in to... this helps clean them up and u can also use the shammie this way and it stops u from getting smeared windows.
Offline ...joe
Re: shammies
« Reply #2 on: 01 May 2005, 21:54 »
use an autoglym hydr-flexi blade!!!
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
mix
Re: shammies
« Reply #3 on: 07 May 2005, 22:48 »
Rinse them out in warm water, maybe a little bit of mild soap, and ringe out and leave to dry.....
* mix housewife mix to the rescue
Offline Dizzie
Re: shammies
« Reply #4 on: 07 May 2005, 23:08 »
We slung them in the washing machine. I've never seen so much soap in there! they look brand new now. we'll see if they still work the same!
mix
Re: shammies
« Reply #5 on: 07 May 2005, 23:09 »
Or theres that option :laugh:
Might have f**ked em up tho as its a wierd material....
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
Re: shammies
« Reply #6 on: 11 May 2005, 21:38 »
i clean shammies at work at the time when doin the cars
if you have a pressure washer just clean the floor so theres a clean patch
then pressure wash both sides nice and clean for you then :cool:
nogama3
Re: shammies
« Reply #7 on: 13 May 2005, 08:22 »
Rob, i thought that would tear the shammy apart?
 bowl of hot water and some fairy iquid as my son says.
Offline VR6_ROB
Re: shammies
« Reply #8 on: 13 May 2005, 19:00 »
nope does not harm it at all mine lasts about 3-4 month but i use it everyday about 15 cars a day
Offline dirtmans
Re: shammies
« Reply #9 on: 03 July 2005, 22:05 »
by the way it's chamois not shammies
