Author Topic: Torque arm bush  (Read 3156 times)
Offline SteveP
Re: Torque arm bush
« Reply #10 on: 05 November 2011, 17:01 »
i suppose its more of a track day part
Yes leave them parts to the stripped out racers imo,
Not for everyday driving, it would wind me up  :smiley:
I disagree TBH, the VWR mount does need a good couple of thousand miles to settle, but is a big improvement over the power flex etc bushes IMHO  :smiley:
I used one on both my Mk5 ED30 DSG and Mk6 GTI DSG daily drivers  :cool:
Offline mkviken
Re: Torque arm bush
« Reply #11 on: 05 November 2011, 19:46 »
couldn't be arced to wait a couple of thousand miles for it to bed in TBH. i can see what your saying but for now the bushing kit will do me.
should be here on monday hopefully
Golf GTI 7.5 230 white silver
Offline mkviken
Re: Torque arm bush
« Reply #12 on: 10 November 2011, 17:09 »
fitted my torque arm insert today
pretty straight forward apart from when i first pressed it in with a packer and trolly jack (with the bolt out as per the instructions) it made the OEM mount crooked and unable to line the bolt hole up. so i had to remove it (not easy!), put bolt back in then make a wooden circle with a hole cut in the centre to clear the bolt so i could press it in with the jack evenly and keep the bolt in a the same time
so anyone fitting one i would say leave the bolt IN while you press the insert into position.
took it for a drive and instantly notice the engine and gearbox are more direct.
there is more vibration at low rpm/idle/pulling away but there is no lurching when changing gears and there is less hesitation between the throttle and the drive train.
a good cheap upgrade
« Last Edit: 10 November 2011, 17:11 by mkviken »
