Author Topic: manifold gasket  (Read 1147 times)
Offline biddy
manifold gasket
« on: 02 November 2011, 20:27 »
hi all how difficult is it to change manifold gaskets on a 20 gti 8v
Offline Seanl
Re: manifold gasket
« Reply #1 on: 02 November 2011, 21:30 »
An absolute ball ache! The mani bolts will probably be corroded as feck, and you will loose lots of skin off your knuckles in the process. Easiest.......well, easier way is to do it from underneath, so if you can get the car up a bit, thats your best bet to take the mani off.
Re: manifold gasket
« Reply #2 on: 02 November 2011, 23:50 »
As above, much easier from underneath or with the car on a ramp.
VW BUSH
Re: manifold gasket
« Reply #3 on: 03 November 2011, 22:21 »
And if the studs snap off its even worse and more £££.
Soak them in plus gas and pray :wink:
Offline sharki786
  • GOT BOOST??
Re: manifold gasket
« Reply #4 on: 03 November 2011, 23:38 »
or use a stud extractor :grin:
whats wrong with the gaskets?
oh p.s good farking luck i had to do mine 3 times and it turned out that its the aux belt slipping c*nt!
*****MK3 Anniversary*****
*****MK4 GTI T*****
