Author Topic: arch work for 7J ET13  (Read 1232 times)
Offline Cory
« on: 02 November 2011, 17:19 »
im thinking about buying some wheels that are 15' 7J ET13 and running them on the mk2, with about a 40mm drop. how much arch work would need to be done?
im a rookie when it comes to wheel fitments
Offline rob.043
Re: arch work for 7J ET13
« Reply #1 on: 03 November 2011, 11:50 »
I'll take a bit of a guess and say no work needed. I had 7j's at one point, cant remember the offset though, and had no issues with a 60mm drop. But its back on RA's and 40mm now....
Offline gavL
« Reply #2 on: 03 November 2011, 15:09 »
It will need no work as long as the tyres aren't from a 4x4.
| DubNorthEast |
Offline Reasty
  • Alpine white valver.
« Reply #3 on: 03 November 2011, 16:21 »
I've got 8x16s with a 35mm offset and a 80mm drop,minor arch work on the front none on the back and dosnt rub at all ever!
VeeDubGTI16v
« Reply #4 on: 03 November 2011, 16:22 »
have you got the -40mm springs on now? if so go and measure how much room you have, you will prob need another 20-25mm outwards with those wheels assuming your wheels are standard. also will depend how stiff your springs are
Offline Cory
« Reply #5 on: 04 November 2011, 00:05 »
thanks for the info guys. i got the car on coilies will have a check 2moro
