Author Topic: jacking points  (Read 8757 times)
Offline ajmoir36
Re: jacking points
« Reply #30 on: 05 January 2012, 19:54 »
I know this is an old thread but I never got round to fitting these,
I was going to fit them over the holidays but then found this, not so sure now, anyone want to buy a spare set of jacking points..  :undecided:
Quote from: VWVortex
This is supposedly a quote from VW:  Only to be used when lifting the entire vehicle using a floor lift. When used together they distribute the weight of the vehicle over the four points. If you use only one at a time, you are putting too much weight on one point and may bend the floor pan.
Does anyone know if this is true?
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline mkviken
Re: jacking points
« Reply #31 on: 05 January 2012, 20:07 »
I've used Mine lots of times now. Jacking just the front or just the rear and not had a problem at all with the floor pan.
Golf GTI 7.5 230 white silver
Offline ajmoir36
Re: jacking points
« Reply #32 on: 05 January 2012, 20:11 »
Thanks for that.
Offline Snoopy
  • Moderator
  • Geoff.
Re: jacking points
« Reply #33 on: 06 January 2012, 08:50 »
Yes it is sort of. The problem is when people jack it too high and end up lifting the entire side of the car up. Or are not carefull placing the  jack so the entire pad takes the weight rather than just one sectiion of it. Also you cannot easy lift it using a U shaped jack pad as this causes issues to lifting forces.
Mk6 GTI  &  Mk1 GTI
35 years of GTI ownership.
Offline Belix
Re: jacking points
« Reply #34 on: 06 January 2012, 20:25 »
better than using the death trap scissor jack and having it fall over. got a nice big dent in the rocker panel the last time I used the OEM one. Will use these jack points from now on thanks...
Offline mkviken
Re: jacking points
« Reply #35 on: 06 January 2012, 21:11 »
yep i would never use the widow maker unless in dire need.
i use a trolley jack and block of wood on the reinforced sill under the arrows to lift the car and use the jacking pads as axle stand locations. or you can use the rear control arm bushing as an axle stand location.
to jack the rear of the car up you need to lift the front end up really high to get the rear of the car off the ground at the same time, as there isn't enough room to get both a jack and a stand on the rear of the car. stupid design.
