Author Topic: jacking points  (Read 8757 times)
Offline Snoopy
  • Moderator
  • Geoff.
Re: jacking points
« Reply #10 on: 02 November 2011, 18:07 »
If you look at Teutonics link and then look at my link you will see that the TT ones are simply push in ones with a much low height than the S3 ones.
The S3 ones stick down more and the front ones come with the covers built in so you don't loose the cover.
Heres the S3 ones
Heres the TT ones
« Last Edit: 02 November 2011, 18:13 by Snoopy »
Mk6 GTI  &  Mk1 GTI
35 years of GTI ownership.
Offline mkviken
Re: jacking points
« Reply #11 on: 02 November 2011, 19:44 »
so the S3  ones can be jacked up without having to remove the trim piece?
i was just going to cut a hole in the existing trim piece to allow the new rubber pad to be fitted and keep the trim piece too. its on
Golf GTI 7.5 230 white silver
Offline Snoopy
  • Moderator
  • Geoff.
Re: jacking points
« Reply #12 on: 02 November 2011, 19:59 »
Yes as the trim peace is a molded in part of the replacment.
Mk6 GTI  &  Mk1 GTI
Offline mkviken
Re: jacking points
« Reply #13 on: 02 November 2011, 20:28 »
looked at the scirocco site and got a good idea of the 2 set ups. didn't realise one had an integrated panel.
i will order a 8PO 802 845 and 8PO 802 846 for the front and just keep the TT rears.
Offline ajmoir36
Re: jacking points
« Reply #14 on: 13 November 2011, 20:22 »
Heres the S3 ones
Heres the TT ones
Right I tried to order all of the above and was told by the Audi dealer they were VW parts all they could sell me were
8P0 802 845 - Not on System (told it was a VW part - clearly not) want (x1)
8P0 802 846 - Not on System (told it was a VW part - clearly not) want (x1)
8N0 804 583 - £1.56 ea  want (x8)
8P0 802 847 - Not on System  want (x2)
8N0 803 855 - £3.06 ea  want (x4)
Need enough to do my Mk6 and my Dads Bora doy they fit the mk5 too?
Can anyone correct the part numbers or was the Audi dealier I tried just a bunch of goons.
Q. Whats the diameter of the plugs? aswell. Ta
« Last Edit: 13 November 2011, 20:25 by ajmoir36 »
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline Snoopy
  • Moderator
  • Geoff.
Re: jacking points
« Reply #15 on: 13 November 2011, 22:02 »
They are Audi S3 only parts so you can only order them from Audi dealer or TPS.  :grin:
They are brand inhibited at a VW dealer :grin:
Mk6 GTI  &  Mk1 GTI
Offline ajmoir36
Re: jacking points
« Reply #16 on: 13 November 2011, 22:38 »
It was audi that I tried to get them from. Will try tps there is one on my way home from work. Anyou idea s if the fit a mark 5?
Offline mkviken
Re: jacking points
« Reply #17 on: 14 November 2011, 09:50 »
i got all mine from audi main dealer no problem same as my S3 OEM short shifter. didn't need a reg or anything just the part numbers
they will fit a mk5
also i used mine the other day fitting my torque arm bushing and they're very good. make lifting the car much safer. no contact with the body at all
Offline Snoopy
  • Moderator
  • Geoff.
Re: jacking points
« Reply #18 on: 14 November 2011, 10:03 »
Yes fit a mk5, and most things based on the mk5 chassis.
Mk6 GTI  &  Mk1 GTI
Offline mike.
Re: jacking points
« Reply #19 on: 14 November 2011, 11:18 »
Phoned my VW dealer this morning and they have ordered the parts.  :smiley:
They service the odd Audi as well so don't see why they couldn't.
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
