Author Topic: Mixture/CO pot settings J plate eight valve  (Read 1294 times)
Offline G-Lader
« on: 01 May 2005, 09:38 »
Hi,
I understand you can set the mixture on the later Golfs - what value should this be set at as Im getting poping coming off the gas - had a new exhaust and replaced the HT leads abd I have been told it may be unburnt fuel due to the misture being a little too rich. Apart from the poping the cars seems to be running pretty smooth.
On my Corrado G60 I take off the co pot adjuster and use a screwdriver whilst monitoring the resistance with a meter in order to adjust, is it the same process? I understand the adjuster is around the air filter box somewhere ? Appreciate some advice as Id like to de this today if poss.
Thanks
Mk 11 8v - Bright blue metallic, 5 door.
Passat 20vT wagon on 18's.
