Author Topic: mk 4 problems  (Read 1355 times)
Offline bank
mk 4 problems
« on: 01 May 2005, 08:51 »
I've got a '98 mk 4 1.8 20v GTI which has developed a number of intermittent faults.
These include:-
- Erratic idle speed.  Usually the idle speed sits around 800rpm but occasionally it races to around 1500rpm.
- Starting problems.  Ususally the car had always started first time no problem.  However, more frequently I find if the car doesn't fire first time it is a complete pig to start taking 5 or 6 attempts.
- Hesitant acceleration, again Intermittent.
Can anybody out there offer any advice?
Steve
Offline kuz
Re: mk 4 problems
« Reply #1 on: 08 May 2005, 14:52 »
Try cleaning the throttlebody out around the butterfly normaly gets coked up.
Offline Alps
Re: mk 4 problems
« Reply #2 on: 09 May 2005, 18:38 »
start with the throttle body as reccomended, then after that It may well be two things, water temp sensor (abt £20) from VAG, easy to replace,then theres the MAS (Mass air sensor) this is a common problem but not so cheap!
Alps
Mk1 Rivage - 1992 Green
E55 AMG 2004
C36 AMG 1997- SOLD
MK4 1.6 SE - 1998
MK1 Rivage - 1991 Blue SOLD
Offline topher
  • Administrator
  • fully functioning
Re: mk 4 problems
« Reply #3 on: 09 May 2005, 18:45 »
i'd say temp sensor.. fits the symptoms exactly and is a very common fault.
Offline bank
Re: mk 4 problems
« Reply #4 on: 21 May 2005, 15:57 »
:smiley:
Thanks for your replies chaps, changing the water temperature sensor seems to have done the trick.
Steve
