Author Topic: Help just lowered my car how do you adjust the camber  (Read 2168 times)
Offline woodymk3_8v
I have just lowered my car with some spax 60mm springs
the problem is the drivers side front wheel sits out more than the passenger.
i would say the passenger one is right looks how it should but the drivers side
need some neg camber to make it match
Offline Burnsy
Re: Help just lowered my car how do you adjust the camber
« Reply #1 on: 01 May 2005, 10:05 »
Probably best to take it to get set up by a garage then atleast you know its set up right
Offline davero
« Reply #2 on: 01 May 2005, 14:20 »
i could only get vw dealer to touch mine, most other places didn,t want to know
Offline gibby
« Reply #3 on: 01 May 2005, 15:46 »
Deffo get this done as I had my cabby lowered the other month and I got some new tyres this week and the old ones had worn on the inside as the camber was well out. Go to a good tyre place and ask them to do the camber and the tracking for you, the one I went to had it computerised to set it all up correctly.
......now officially dubless.
Offline woodymk3_8v
« Reply #4 on: 01 May 2005, 18:09 »
anyone know any good places in or near colchester essex
Offline gibby
« Reply #5 on: 01 May 2005, 21:38 »
Go to any good tyre place that you use.
Offline carl
« Reply #6 on: 01 May 2005, 22:14 »
i had coilovers put on and mine, camber was miles out cost me 60 quid at apb motorsport staffs ,i found all your regular tyre places did not do this job ,if you undo the 2 bolts at the bottom of shocks you can move the camber in or out ,but i would get it done by pro.
Offline customboy
  • I LOVE MY TURBO!!!
« Reply #7 on: 01 May 2005, 23:34 »
well i had a problem with my camber and had to get it sorted i used a company call elite direct based in rainham essex they charge just 39.99 to do camber alignment and are one of best places i have been more info on the website add below
www.elitedirect.com
hope this helps they are the daddies!
customboy
