Author Topic: Requirements to lowering my golf  (Read 1124 times)
Offline brothy
« on: 31 October 2011, 17:26 »
If i purchase some coilovers and lower my car, will i require anything else such as adjustable drop links etc ?
I just want to be 100% sure of what i need
Thanks
Offline sveed1.8T
Re: Requirements to lowering my golf
« Reply #1 on: 31 October 2011, 17:32 »
I'd recommend new top mounts regardless. If you're going lower than 40mm drop, you'll need an uprated ARB (like the TT front ARB). I have no expertise in adjustable drop links, so someone else will need to educate you on them, but I think they're needed if you're going real LOW :cool:
Offline dom
  • Back in a Mk4
« Reply #2 on: 31 October 2011, 17:35 »
A chassis notch may also be required depending on how low your planning on going.
Offline brothy
« Reply #3 on: 31 October 2011, 17:42 »
30 - 50mm maybe not even that
Offline GJSEB79
« Reply #4 on: 31 October 2011, 18:37 »
i thought above was when you was riding air ride suspension
Offline cullygti
« Reply #5 on: 31 October 2011, 18:52 »
uprated arb shpuld be fine as said new top mounts maybe a 5mm spacer on the front wheels depending on wheel size of course  to clear the adjuster on the coilies if your going really low  :wink:
