Author Topic: Strange Faults - Video Inside  (Read 5137 times)
Offline Yohan
« on: 30 October 2011, 18:42 »
Evening all,
Having some issues with my Bora S3 and it's phantom/random fault codes.
I'm not sure if some of them are having a knock on effect on each other so hopefully you can help.
The modules of concern are below.
Address 03: ABS Brakes        Labels: 1J0-907-37x-ESP-A.lbl
   Part No: 1J0 907 379 AB
   Component:  ESP     20   CAN  V005
   Coding: 00214
   Shop #: WSC 31414
   VCID: 71EC41AD1132
No fault code found.
OR
   Coding: 00214
   Shop #: WSC 31414
   VCID: 71EC41AD1132
1 Fault Found:
01324 - Control Module for All Wheel Drive (J492)
            49-10 - No Communications - Intermittent
OR
   Coding: 00214
   Shop #: WSC 31414
   VCID: 71EC41AD1132
1 Fault Found:
01314 - Engine Control Module
            79-00 - Please Check Fault Codes
Notes: -
4wd system appears to operate correctly.
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 6Q0 909 605 A
   Component: 0F AIRBAG VW5  01   0004
   Coding: 12358
   Shop #: WSC 31414
   VCID: 3564B5BD25DA
1 Fault Found:
00588 - Airbag Igniter; Driver Side (N95)
            32-00 - Resistance too High
Notes: -
I think the slip ring behind the steering wheel is broken as I can hear the ribbon cable cracking, also the horn doesn't work.
Address 22: AWD        Labels: 02D-900-554.lbl
   Part No: 02D 900 554 C
   Component: HALDEX LSC  ECC     0010
   VCID: 204A74E98A58
1 Fault Found:
OR
   VCID: 204A74E98A58
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
OR
   VCID: 204A74E98A58
1 Fault Found:
00526 - Brake Light Switch-F
            27-00 - Implausible Signal
Notes: -
The traction control/ESP light is ALWAYS on. Pressing the ESP button does nothing other than make the light flash.
Even if I clear all the fault codes the light will still come on and eventually one of the above faults will show itself again. See video below.
VIDEO HERE once photobucket works
My first action is going to be replacing the steering angle sensor (airbag slip ring), and the brake light switch.
I also have a light weight Powervamp racing battery in the boot instead of the stock model. It reads 14v when the car is running. Would this be causing any problems?
All other thoughts and suggestions welcome, would quite like a fault code free car :)
« Last Edit: 30 October 2011, 18:43 by Yohan »
