Author Topic: Radio arial  (Read 1233 times)
Offline Domo
Radio arial
« on: 30 October 2011, 11:14 »
The radio gets sh!t signal cause the arial doesnt raise up and i cant figure out how to get at the arial. also can i change the actual type of arial?
oh and its a Golf CL
Offline dom
  • Back in a Mk4
Re: Radio arial
« Reply #1 on: 30 October 2011, 11:20 »
I'm guessing you have a wing mounted aerial? If so then as far as I'm aware they aren't motorized, you'll have to pull it up manually.....
Offline Domo
Re: Radio arial
« Reply #2 on: 30 October 2011, 11:24 »
aye its wing mounted but i cnt pull it out for as it goes into the holder part pretty smooth so there no gap to pick it out. if i do get it up is there any chance i can change it
Offline dom
  • Back in a Mk4
Re: Radio arial
« Reply #3 on: 30 October 2011, 11:33 »
I had a little key which slotted over the top of the aerial & allowed me to pull it up. You could take the wing off to fit a new one, personally I'd look out for one from a scrappy without the aerial hole & fit a glass mounted aerial instead.
Offline Domo
Re: Radio arial
« Reply #4 on: 31 October 2011, 12:31 »
Dnt suppose u have a picture ofthe key or could explain wat it looks like?
Re: Radio arial
« Reply #5 on: 31 October 2011, 13:52 »
If the top is smooth it might be electric.
Offline vdubnut
Re: Radio arial
« Reply #6 on: 31 October 2011, 22:31 »
cl one on mine a manual got a replacement from ebay but runnning a window mounted one but reception on thats not that good :( may go back to wing ariel!
wheel liner removed can get access to the ariel end but need wing off to access cable run..
