Author Topic: few niggles I need to sort  (Read 1117 times)
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
« on: 30 April 2005, 20:34 »
Right folks I been hearing a problem over past few weeks
only seems to happen when im in 5th but today it was doin it in
2nd n 3rd aswell it seems to be some sort of whistling noise,
when i go faster
the whistling gets higher pitched if you no what i mean and its annoying
need it sorting out
also when i pulled up at home after id been cainin it down bypass to hear the noise
i could smell strong burning smell but i dont usually
and when i go down a hill n hit the brakes it sort of growls when it slows down
if its nothing to worry about i will leave it until later in the year when it gets
loads done to it but i will sort it if its easy.
but any help would be appreciated cheers
Offline Deefadog
  • Mk2 16V (November 89)
Re: few niggles I need to sort
« Reply #1 on: 01 May 2005, 23:06 »
Fan belt or power steering belt may be too tight?
I think if you can twist it with your hand and the belt will ben 90 degrees you should be ok!
Good luck
Offline VR6_ROB
« Reply #2 on: 02 May 2005, 11:39 »
belts are ok they just been done power steerin may need adjustin though
i think whistlin noise is the gearbox
no oil i think is the cause as i had a slight driveshaft seal leak
it was topped up january time then i forgot about it
Offline Andyfitz
« Reply #3 on: 02 May 2005, 11:51 »
Is it a whistle or a more of a whining sound?
And does it happen on breaking? worse or jsut the same?
Offline VR6_ROB
« Reply #4 on: 02 May 2005, 13:06 »
when i break from high speeds it sort of growls
i have just been outside n gearbox took 1litre of oil n never overflowed
so i have a feelin its that lol
i hope i caught it in time though
