The garage
Engine splutter @ 60 in 5th gear
Topic: Engine splutter @ 60 in 5th gear (Read 4102 times)
rosco
Just got here
08 May 2003, 12:47 »
I've just bought a 1989 8valve. Its running great apart from in fifth gear around 60mph when the engine seems to be miss-firing when the accelerator is half way down?
however if i floor it, its fine?
Please tell me it can be fixed!!!
Last Edit: 01 January 1970, 01:00 by 1055631600
alz
Just got here
Re:Engine splutter @ 60 in 5th gear
27 June 2003, 12:16 »
Hi there, I also have a mk2 8v gti, and am suffering a very similar problem, I have spoken to my local vw garage, who tinkered with it, but am still trying to find a remedy. If I find out the solution, will post it on here.
Alz
gti69
27 June 2003, 13:52 »
I had a very similar problem to you. I took my car to a rolling road and they found out that my timing out was by nearly 20 degrees!
My car car would drive fine when your foot was pressed down about half way but any less than this the car would feel like it was mis-firing.
The car had the timing reset and performs brilliantly now. I thought it was fast before but it much smoother now! BTW it's a 91 8v Gti
Hope this helps.
Last Edit: 27 June 2003, 13:54 by gti69
The garage
