Author Topic: mk3 on 17"s  (Read 3183 times)
Offline G.t.I-JOE
Re: mk3 on 17"s
« Reply #10 on: 29 October 2011, 00:17 »
How easy is it to remove trims? also did u need spacers?
Re: mk3 on 17"s
« Reply #11 on: 29 October 2011, 00:20 »
Dead easy and I never ran spacers.
You will need to trim the rear arches a little.
Offline G.t.I-JOE
Re: mk3 on 17"s
« Reply #12 on: 29 October 2011, 00:23 »
 :huh:Trim how is this done?
Offline dom
  • Back in a Mk4
Re: mk3 on 17"s
« Reply #13 on: 29 October 2011, 00:24 »
The biggest problem with Gti's is that the trim acts as a water trap. You'll be very lucky to remove the trim and not find rust lurking underneath :sad:
Re: mk3 on 17"s
« Reply #14 on: 29 October 2011, 00:27 »
Angle grinder  :smiley:
Offline G.t.I-JOE
Re: mk3 on 17"s
« Reply #15 on: 29 October 2011, 00:28 »
Oh not good then mite be lucky tho :tongue: will have ton have a look do they just clip on and off?
Offline G.t.I-JOE
Re: mk3 on 17"s
« Reply #16 on: 29 October 2011, 00:30 »
Would arch rolling be as affective as a angle grinder? sound like it could get messy!!
Re: mk3 on 17"s
« Reply #17 on: 29 October 2011, 00:31 »
Better tbh :afro: I only used a grinder as it was the cheapest option.
Offline dom
  • Back in a Mk4
Re: mk3 on 17"s
« Reply #18 on: 29 October 2011, 00:31 »
You have to drill out the rivets on the underside of the trim :wink:
Re: mk3 on 17"s
« Reply #19 on: 29 October 2011, 00:32 »
And if leaving them off you will need CL trim.
