Author Topic: 01259 - Fuel Pump Relay (J17) 28-00 - Short to Plus  (Read 3985 times)
Offline jamie1989
« on: 27 October 2011, 16:28 »
I am having the above fault code everytime  :sad:
I have changed the relay it self but no luck and its doing my head in.
Abit of history my Bora was once a measley 1.6 but now a 1.8t AGU.
I didnt complete the conversion myself but under the battery tray I can see that the loom is block connectored up but looks cool to me.
The car runs spot on, I just dont like seeing the fault code I simply cant just ignore this lol its there for a reason.
The pump primes itself when opening the door and starts first time.
I have heard the 1.6 is SIMOS and the 1.8t (AGU) is Motronic what does this mean?
Any suggestions?
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline javalin
Re: 01259 - Fuel Pump Relay (J17) 28-00 - Short to Plus
« Reply #1 on: 31 October 2011, 14:50 »
sounds like the fuel pump relay is faulty / or wiring faulty.
http://wiki.ross-tech.com/wiki/index.php/01259
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline jamie1989
« Reply #2 on: 04 November 2011, 10:41 »
I have no idea.
Its not the actual relay itself as Iv changed mine 3 times to eliminate the problem.
I have checked the wiring and it looks ok.
But it is a conversion so am I using the wrong loom to connect the wiring loom from plenum chamber to engine loom  :undecided: this may cause my problem with the fuel pump relay, I duno.
I have used the 1.8t engine loom and block connectored the car loom (under the battery tray that goes to the plenum chamber drivers side)
