Author Topic: td AAZ in a T25  (Read 3090 times)
Offline *tell*
td AAZ in a T25
« on: 26 October 2011, 23:43 »
friend has a AAZ td engine in the back where a 1.6 td engine was and now
and then the oil buzzer goes off? is the because the engine is on it side
(has a different oil pick up tube). or because to oil pressure is different
in the new engine? is was running fine in the mk3 it came out from.
thanks tell
Offline danny_p
Re: td AAZ in a T25
« Reply #1 on: 26 October 2011, 23:46 »
if he's swaped the sump and pickup it should be fine.
oil pressures are about the same, has he connected th switches the right way round ?
all the VW's have gone bar 1.
Offline *tell*
Re: td AAZ in a T25
« Reply #2 on: 27 October 2011, 18:41 »
thanks for the reply its had a sump and different pick up tube fitted.
