Author Topic: which mid steel sheet thickness for welding golf?  (Read 7129 times)
Offline Mann
« on: 26 October 2011, 22:48 »
I need to know what thickness mid steel sheet for me to cut and weld for golf mk2?
Because I will use steel sheet to replace the rot on arches and floor of golf driver.
Any suggestion?  :smiley:
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: which mid steel sheet thickness for welding golf?
« Reply #1 on: 26 October 2011, 22:52 »
I used 1mm stuff I bought off ebay for my Mk3.
Offline Mann
« Reply #2 on: 26 October 2011, 23:20 »
Cheer that all i need to know  :grin:
Offline DOA
« Reply #3 on: 27 October 2011, 13:10 »
Depends on the area that needs welding. The parent material on the front and rear arches appeared to be around 1mm when I did them recently but the repair panels I got for these areas and the rear valance were more like 1.5mm. Can you not just measure it locally in the areas you are going to be replacing?
Offline Sam
  • Sam I am
« Reply #4 on: 27 October 2011, 13:20 »
Yer but yours had to be iceberg proof too
Offline Gti_Jamo
« Reply #5 on: 27 October 2011, 14:02 »
Very Funny :cry: You can cut the ribbon on its maiden voyage if you want!!
Offline danny_p
« Reply #6 on: 27 October 2011, 23:01 »
repair pannels are much easyer
all the VW's have gone bar 1.
Offline tshirt2k
  • Been there...Done that...
« Reply #7 on: 28 October 2011, 08:07 »
Mostly 20 gauge but some areas like floor are 18 gauge which is thicker.
Mk3 ABF 16VT Megasquirt V3
Offline Neo Badness
  • Feet are for pedals
« Reply #8 on: 30 October 2011, 12:06 »
+1
 Hadrian auto panels are cheap and cheerful. Ebay sell various repair panels for not too much cash. Floors can be had from VW heritage. Speaking as someone who's done a lot of resto' including floors, I'd buy the panels unless it's only a tiny bit.
You may save money buying sheet steel but you'll spend longer fabricating to get a not so great job.
Offline Ben Lessani
« Reply #9 on: 30 October 2011, 12:59 »
When I fixed up my sills, I used 16 AWG for the inner sill and 18 AWG for the outer and floor sections. Spot and seam welded.
