Author Topic: anybody?  (Read 1671 times)
Offline Phil18t
anybody?
« on: 26 October 2011, 10:45 »
running a 3"downpipe/decat with a standard exhaust??
Offline Rhyso
Re: anybody?
« Reply #1 on: 26 October 2011, 10:46 »
Patch did I believe
Offline Phil18t
Re: anybody?
« Reply #2 on: 26 October 2011, 11:20 »
just wanted to know if there was much difference in sound and performance really?
Offline Rhyso
Re: anybody?
« Reply #3 on: 26 October 2011, 11:28 »
You'll have to ask him but I believe it helped with performance but made little difference to the sound  :undecided:
dellenty69
Re: anybody?
« Reply #4 on: 26 October 2011, 11:57 »
you will also need a reducer from 3" down to 2/75"  i believe.
performance increase yes due to more flow, but the standard exhaust has some pretty impressive silencers on it!
Offline jnufcuk
Re: anybody?
« Reply #5 on: 26 October 2011, 15:08 »
That's what I'll be running except with a sports cat but standard back box and tail pipes.
Offline Big Tone
Re: anybody?
« Reply #6 on: 26 October 2011, 16:19 »
What about if you take the middle box out and run straight through to the backbox?
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: anybody?
« Reply #7 on: 26 October 2011, 16:27 »
If its the same set up as the Leon Cupra which I believe it is the centre pipe from a diesel will fit it. Which is silencerless. I put one on mine and it made it a bit raspier although I haven't got a 3" downpipe or decat. Part was like £12 if I mind right from local motor factors. You see them advertised as 'race tubes' on ebay for like £40.
Offline Big Tone
Re: anybody?
« Reply #8 on: 26 October 2011, 16:30 »
Think its advertised as a pd130/140 middle pipe?
Someone confirm/correct me if im wrong.
Offline rio_gti
Re: anybody?
« Reply #9 on: 26 October 2011, 17:03 »
i done it, turbo spools proper loud and there was a slight increse in power, but sounded the same tbh, the main improvement in performance and sound was when i put the anni exhaust on (cat back) but i still think it is holding back a nicer note and a touch more power so i am going to be removing the centre box sometime in the near future.....
