Author Topic: mk4 1.4 golf idle  (Read 3344 times)
Offline hotdogsmale
  • You just cant go wrong with a golf!
mk4 1.4 golf idle
« on: 26 October 2011, 08:30 »
hi there just brought a mk4 golf 1.4 and its strange because it starts fine but then runs for a bit all good then turn it off and turn it on and idles a bit lumpy as in nearly stalls but never does then rev it up to about 2000 for a bit qand then its fine again anyone no the prob ill prob do a service on it could it be a fuel filter slightly blocked or something? cheers
Offline mcgee9t2
Re: mk4 1.4 golf idle
« Reply #1 on: 26 October 2011, 10:30 »
Had it scanned. sounds like the problem i have. mines the maf.
lukily for you i think the mafs cheeper on the 1.4.
Offline hotdogsmale
« Reply #2 on: 26 October 2011, 10:33 »
ok bud ill check it out :)
Offline 1.6mk4GOLF16v
« Reply #3 on: 26 October 2011, 11:00 »
isnt it a MAP sensor on the 1.4?
1.6 16v AZD
RS8s 225/35/19
Full powerflow decat exhaust
Blanked EGR
Pipercross panel filter
watch this space for the rest...
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« Reply #4 on: 26 October 2011, 11:10 »
Clean throttle body  :smiley:
Offline hotdogsmale
« Reply #5 on: 26 October 2011, 11:26 »
ok on these are they self adjusting when you put them back on just start up and leave to idle? and will reset its self? cheers
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« Reply #6 on: 26 October 2011, 11:39 »
If its a cable operated TB, then it will reset itself after about 100 miles, if its the other (electronic TB) then I think you  need to re-align it with Vag-com.
dellenty69
« Reply #7 on: 26 October 2011, 11:56 »
and before you ask, you need the full version of vag-com (vcds) to be able to re-align
Offline hotdogsmale
« Reply #8 on: 26 October 2011, 12:11 »
lol ok so you no there defo electric? lol
Offline bullzeye
« Reply #9 on: 26 October 2011, 12:16 »
my 1.4 did the exact same thing when i stopped at traffic lights the revs would drop them jump up then drop so low it would cut out, paid £10 for garage to clean throttle body and it never did it again, you can do this yourself theres a guide on how to do it on here but for £10 i just got garage to do it. that would be first thing id advise you to try  :grin:
cheapest mobile provider arround order a free sim with £5 credit www.giffgaff.com/orders/affiliate/s3cr3t
