Author Topic: N249 Bypass  (Read 5615 times)
Offline Phil18t
N249 Bypass
« on: 25 October 2011, 19:50 »
Had a flat spot/surge at around 2200rpm on light throttle more noticable in 2nd, after looking on here about the N249 bypass solving the problem i carried this out, at first it seemed loads better but i noticed it still has a slight surge at the same sort of rpm now and again. i have a carbonio on so i can hear it dump the pressure even with my foot still lightly on the throttle?? dont know how because the 007 valve is purely connected to the manifold/fpr now? could it be N75 or throttle body needs cleaning?
Re: N249 Bypass
« Reply #1 on: 25 October 2011, 20:21 »
Dom did send me this excellent guide on the bypass mod, http://uk-mkvs.net/forums/t/265883.aspx
Offline Phil18t
Re: N249 Bypass
« Reply #2 on: 26 October 2011, 09:53 »
already done the bypass, not this way tho.. n still got flat spot/surge.?
dellenty69
Re: N249 Bypass
« Reply #3 on: 26 October 2011, 12:07 »
the bypass you have probably done is the actual N249 BYPASS.
That guide Wayne posted is more of a N249 removal.
remove the hose coming from the actuator to the N75 (remove it at N75 end) and clamp the hose off on the end. take it for a drive. that's one way to test the n75, but i couldn't imagine it due to the requested boost at 2200rpm will be nothing.
have you checked your MAF? unplug your MAF and go for a spin, if it runs better and smoother then that's your problem.
both of those things will cause a fault code to be logged, so you will need them both to be cleared after attempting them.
Offline Phil18t
Re: N249 Bypass
« Reply #4 on: 30 October 2011, 21:23 »
anybody know what could still be causing this?
Offline dom
  • Back in a Mk4
Re: N249 Bypass
« Reply #5 on: 30 October 2011, 21:59 »
Only just seen this thread, is the flat spot when your on full throttle/part throttle/both?
Offline Phil18t
Re: N249 Bypass
« Reply #6 on: 31 October 2011, 21:04 »
just light throttle mate, like in second and just slowly accelerating off a speed bump..u feel a flat spot about 2000rpm and you can hear a little dump through my carbonio..
Offline dom
  • Back in a Mk4
Re: N249 Bypass
« Reply #7 on: 31 October 2011, 21:09 »
Mine has a really bad flat spot just after 2000rpm as well, but only on part throttle, never on full throttle :undecided:
I can't help but if you find the solution then let me know!
