Author Topic: LED Rear Lights  (Read 18407 times)
Offline EyeballPaul
Re: LED Rear Lights
« Reply #100 on: 23 December 2011, 16:39 »
They sure are plug and play, real easy to install takes about 20 mins. Not sure if you will need any coding doing, as you have xenons so just make sure the ignition is off when you do the job. At worst i think you may get a bulb out error that will need to be reset, but the lights should work fine. Mine worked exactly as they should.
Offline guy444444
Re: LED Rear Lights
« Reply #101 on: 23 December 2011, 21:37 »
Hi
Thanks for responding
Appreciate it
Will give it a go and report back
Offline guy444444
Re: LED Rear Lights
« Reply #102 on: 08 January 2012, 22:06 »
LEDs installed
Offline EyeballPaul
Re: LED Rear Lights
« Reply #103 on: 09 January 2012, 10:28 »
Hope it all went as straight forward as mine, they do look so much better
