Author Topic: LED Rear Lights  (Read 18406 times)
Offline Spin 150pd
LED Rear Lights
« on: 25 October 2011, 12:44 »
I know I should use the search function but there is quite a lot of info to go through :wink:
I'm looking into upgrading to the LED rears,  my car is a July 09.
Can someone advise ..
1. what I need
2. How much
3. Where from
Many thanks
Carbon Grey 3 Dr GTi, AP racing BBK,  ITG Intake, Milltek Race TBE & Revo Stage 2+ (sold) Replaced with 2010 S3 Sportback
"Fast Cars are safer.."
Offline AlanD
  • MK5 2.0T 16v
Re: LED Rear Lights
« Reply #1 on: 25 October 2011, 13:15 »
At the risk of sounding like an old man yes you should have used the search function. Found this link in a thread after 30 seconds of looking - http://www.mk6golfgti.co.uk/forum/index.php/topic,81.0.html
If you dont want to take on the task yourself any VAG garage worth its salt will be able to do it for you.
Re: LED Rear Lights
« Reply #2 on: 25 October 2011, 14:16 »
Snoopy was the most recent person on here to purchase the rear lights, from memory.
Yours may well be okay, but some 09 cars (like my previous mk6) get a bulb out light in the dash even after VCDS coding. You quickly get used to it but it is a nuisance none the less.
Mine was one of the launch cars though and I'm not aware of too many that had the issue.
Offline Spin 150pd
Re: LED Rear Lights
« Reply #3 on: 25 October 2011, 14:48 »
Mmmm thats my fear,  a bulb out light or any light for that matter would negate the benefits of having them for me as a bit of a perfectionist.
If only there was a 100% way of knowing either way. :undecided:
I guess I should have done some additional homework before buying the car then i would have been aware of these subtle differences,  the fact is I was blown away by the cars looks and stance when I saw it at a BMW franchise whilst in for a service, little did I know things could get better.
Oh well I got if for a good price so I'll have to keep investigating unless someon pops along with a definative answer :smiley:
Offline Ess_Three
Re: LED Rear Lights
« Reply #4 on: 25 October 2011, 14:55 »
What age is your GTI?
Mine is April 2010 and had no issues with the coding, once I finally got the correct coding for factory Xenons and LED rears.
I guess if your car has the same controller as mine, or newer, it will be OK.
..but gaining motorcycles.
Re: LED Rear Lights
« Reply #5 on: 25 October 2011, 15:29 »
Where in the country are you Spin?
Offline Spin 150pd
Re: LED Rear Lights
« Reply #6 on: 25 October 2011, 15:45 »
The midlands,  live near Ashby De La Zouch.
Car is a July 2009 so could well be a launch model.
Offline SteveP
Re: LED Rear Lights
« Reply #7 on: 25 October 2011, 15:46 »
VCDS scan is the only way 100% confirm the situation. However, if the car is on an 09 plate and doesn't have Xenon's 99% of the time it will require a CEM upgrade to support LED rears from my experience.
Offline Spin 150pd
Re: LED Rear Lights
« Reply #8 on: 25 October 2011, 17:11 »
If this is the case Steve what cost am I looking at ?
Jimmymature
Re: LED Rear Lights
« Reply #9 on: 25 October 2011, 17:50 »
My car is an early car too and needed a new BCM, I purchased one that supported LED rears. It cost £90 and I purchased it from eBay.de  SteveP then very kindly switched my BCM over and everything is working perfectly.
Cheers,
Jim
