Golf mk2
8v Gearbox on a 16v - Straight forward?
Topic: 8v Gearbox on a 16v - Straight forward? (Read 1338 times)
iyda
Just got here
24 October 2011, 22:52 »
In my struggle to find a gearbox for my '91 MK2 GTi 16v 1.8 it is looking more like i am going to have to go for an 8v box.
Just got a couple of questions!
Is it a straight forward swap, do i just need to get an 8v clutch?
Will it affect the performance in any way, or is it not really noticeable?
Wayne
Sir Postalot
Re: 8v Gearbox on a 16v - Straight forward?
24 October 2011, 23:36 »
Yes you need to change the clutch but I think the ratios are wrong
Agreeable Slick
Global Moderator
Serious forum addict
Unit
25 October 2011, 08:38 »
Have a go on the search function.
There is also this in the maintenance section:
http://www.golfgtiforum.co.uk/index.php?topic=30850.0
Ratios are generally very similar, it's just the final drive that's different.
You will need a new clutch set up as the splines on the output shaft are different in number, 24 to 21 I think.
I made this : ->
https://www.golfgtiforum.co.uk/index.php?topic=30416.0
iyda
Just got here
25 October 2011, 12:42 »
Ok, apologies for sounding thick! I don't know anything about this sort of stuff! :embarassed:
So, i have seen an AUG box from an 8v, will this fit into the 16v as long as the clutch is changed too?
Golf mk2
