recently i have been having intermittent issues with the drivers window sticking if you like. i can press the button and the window wont go down then if i try again it will go down but i have to reset the automatic function.
Now whats happening is that the drivers window wont move anywhere at all and if i attempt to wind the front passenger window down from the drivers side switch it goes all the way down and wont come back up again from the same switch unless i lean over and operate it from the passenger window switch..... i havent done any investigation into it as of yet, but i know i can rule out the switch...??
Has anyone else had this problem before???
Thanks
